Indefatigable
You guys better not stack any rocks- Vince and I will be coming through about one week later. Have fun!
:drinks:
Forgot to ask, cans or bottles?
This is great can you please add me and Kevin to going list along with Don and lori![]()
Yep, Lori and I are in along with Ray and his son Kevin!
A lot of the breaks that you see on the Rubicon are ones that can be prevented simply by making sure your Jeep is in tip-top condition prior to you showing up at the trailhead. The following checklist has been created to help you go through your Jeep and ensure it's ready to be put to the test. These checks should be done after your last wheeling trip and PRIOR to doing the rubicon.
Rubicon Pre-Run Checklist:
1. Make sure your Jeep is current on all it's routine maintenance and fluids are at capacity (i.e. oil changed, differentials serviced with visual check done, transmission/transfer case serviced, air filter clean, radiator full, brake fluid level full, etc.)
2. Check all your U-joints for any signs of cracks, rusting around the yokes/bearing caps and missing c-clips if you have them. If you haven't replaced your U-joints in over 2 years, you should pull your shafts and check them by hand or just replace them as a part of normal maintenance.
3. Check the splines on your axle shafts to see if there's any twisting in them. Replace as needed.
4. Check your ball joints and tie-rod ends.
5. Torque all your suspension and steering component bolts.
6. Torque your lug nuts.
7. Grease all suspension, steering and driveline components that have provisions for greasing.
8. Check your suspension and steering mounts on the frame and axles and make sure there are no signs of cracking, tearing or fatigue. Repair as needed.
9. Check your aftermarket wiring for any signs of chaffing, crumbling, melting or wear. Replace as needed.
10. Check your battery to make sure it's in good condition and is holding a strong charge. Replace as needed.
11. Check your tires for any abnormal bulges, cuts, tears, leaks or damage. Repair or replace as needed.
12. Check your winch if you have one and verify that it works and that the rope is in good condition. Replace as needed.
So that it's clear, after going over this checklist, DO NOT plan any wheeling trips until you get to the Rubicon - I MEAN IT. The Rubicon is a demanding trail even under the best of conditions and, in an effort to make it as fun as possible, we want your rig to be as fresh and ready as possible. I really hate to be so strict about this but, if you cannot do this, I would be grateful if you could please recuse yourself from this run.
Please let me know if you have any questions.
BTW - I would like this to be a NO GAG trip - seriously! I know we've had a lot of fun with this over the years but, in my opinion, it's starting to get out of control and I would be grateful if you could please leave it at home. Thank you.
In if there is room
Eddie! Thank you for this great check list. I plan on printing it out and using it to get the Jeep ready. People know me as the guy that over maintains my vehicles and the Jeep is no exception. Consider it done!
Tony..
By checking your splines do you need to pull the axle out or just the diff cover?
Serg5000 said:I just came off the Rubicon today. Let me say this. For those going for their first time, this trail will change your life. Enjoy everyone.
wayoflife said:Just checked the weather for Loon Lake and it looks like by Sunday, we'll be seeing daytime temps in the 80's and night time temps in the 50's!! Hopefully it'll stay this way and if it does, it's gonna be awesome :wings:
Sorry to say I have to drop out of this year’s Rubi run because of work related issues. I hope you all have a fantastic time. :-(
