Well doesn't look like I'll be able to swing this one. You all have fun!
Ty that sucks. Was looking forward to seeing you again.
Damn dude. Was looking forward to seeing you there. Take care
There really isn't a Black-Blue group. The group running Blacks will be running closer to and including Reds. Also, This group is very full. Even if people drop out we would prefer to not back-fill.
Do you still want in the Green Group?
Edited this post because i just talked to my girlfriend. Im sorry guys but I'm gonna have to sit this trip out. Hope you guys have a blast! Hope someone can take my spot!
I'm in for greens and some easy blues.
I will also have 2 other rigs with me.
Cutting it close for me an parts. I hate to say, but to daily a jku everyday an wheel it really takes it toll. the past two months ive had to replace my trans solenoid, an my winch line since it started to fray.
Its really affected my beadlock funds. Also found out my rear axles are bent... So would it be safe to wheel with bent axles? I will be making all kinds of noise on the trail, it already squeeks like crazy because the hubs is pushing the rotors at weird angles.
Or should I swallow pride an do green trails this time around? :grayno:
any advice guys? thanks
I have my old stock shafts that are not bent. Not sure if they are good since they have been sitting outside tho.
Tyler if you dont want to wheel it you can always ride along with me.
Not having bead-locks shouldn't be an issue. When you say bent axles I assume you meant the flange? If so, it (sadly) is very common. It is totally up to you but, but we will be hitting some stuff that has the potential to make it worse (or if you are lucky bend them back). If they get too bad you could be looking at also needing brake parts. How bad are they now?
As far as moving to the Green goes.... That group is already more full than I think is fair for one leader. If you move would you be comfortable leading or at least co-leading a second group like we will be doing in the Black/Red group?
Tyler if you dont want to wheel it you can always ride along with me and help me lead.
