I just put this lift on last week, love the ride. However, Not sure if its normal but it lifted quite a bit more up front compared to rear. I know it should a little but the front ground to fender is 38.75 and rear is just under 36.5. The space in the fender from tire to fender is 7.5 in front and barely 5 in rear. Also I needed a spring compressor to get the passenger side spring in because I couldn't get it to droop low enough. The instructions said it would fit right in. Im wondering if I ended up with the 3" springs by mistake. Or maybe I just need larger spacers in the rear. Anyone else have these comparable measurements?
View attachment 130506View attachment 130507 I ordered the kit from Northridge. It does seem to ride great though, my steering is just a tad off center, I will fix that when I get the alignment done.
