15 Anvil JKUR HR Build
Speedy_RCW
I think the paint finish looks good like that. Plus, easy to touch up.
Thanks and yea it does. Got a couple scratches putting the final cage back in.
So I finally got everything re-installed. Glad to have my Jeep back. Genright gave me the incorrect hardware for the rear seat belt retractors so I gotta get to Ace for a couple nuts. I think it turned out pretty good. Just have some cosmetic stuff to work on over time in regards to the trim. Here’s a few pics.
Speedy_RCW
Looking good! I imagine that is a heavy sob as a whole getting back in place
Thanks. It’s heavy but luckily I installed an electric hoist in my garage for taking off the hardtop. So I used that to remove and install the cage. :thumb:
That looks really good. Nice job. [emoji1360]
Looks awesome! Subscribed [emoji106]
Thanks guys.
Speedy_RCW
Swapped out my PSC Big Bore XD box with the XD-II box. Steering is much smoother now. I’ll do the upgraded pump in the future but with Moab coming up in April, I don’t want to have too many new, untested parts on the Jeep. The new box is quite a bit larger than the old. Also makes it a little harder to lift it into place.
Coop
Smart! Looks good!
Speedy_RCW
Picked this thing up today to start messing around with. Still hunting for a good deal on a front. Thinking I’ll probably get around to swapping next winter most likely.
Speedy_RCW
Started dinking around with this 14 bolt tonight after a couple beers. It turned out to be in pretty good shape. Only issue I found was it looks like slight leaks on the axle seals. Especially the passenger side. No big deal since I planned on new bearings and seals all the way around. May stick with the existing calipers since they also seem to be in pretty good shape. I guess it’s time to start ordering up a few parts. But here’s a couple pics.
Speedy_RCW
Finished up the hubs on the 14b. Well except for one bearing that RockAuto shorted me. That should be here tomorrow.
Chucked up in the lathe checking run out before turning down for tone rings.
I was surprised how much the castings differed. I had the runout at 2 thou and when I started the lathe it was wobbling pretty good. I though I screwed something up but it was just how it was cast. The second one didn’t wobble near as much.
The Artec tone rings look nice but they weren’t perfectly round which made getting the fit right a little tricky. I took the average of the high and low plus .005 for the hub dimension.
Having a bearing warmer was helpful too. :thumb:
Painted, installed bearings and seals and also pressed in SAE studs since the factory ones were metric.
I think my next step will be the shave. Seriously looking forward to that! 🤪
Seahawkfan
Have no idea how to do what you do. But I sure do like your choice of RUGS.. Haha Go Hawks. I dig your jeep too.
Speedy_RCW
Impressive. You have all these tools at home?
No, the lathe and press are at work. To my knowledge that lathe has only ever been used for personal projects. Lol
Go Hawks! And thanks.
Nice project.... looks great!! Can’t wait to see the finished product...!!
Well I don’t want to build the anticipation too much. It’s gonna happen pretty slowly. More or less just something to tinker with in my spare time. And with another baby on the way, I’ll have even less time. I think these will realistically be installed next winter. 🤷🏻*♂️
