WJCO
Meme King
Haven't seen that used before. I would just get the cheapest gear oil you can find.
Newbie question:
I just spray the brake cleaner on everything and let it evaporate? Is this to help get the old oil off?
Newbie question:
So I have everything I need to do a diff fluid change but I'm wanting to get a heavier duty cover. I ordered a pair of poison spyder covers but they won't be here for a week or so. The problem is that I just got new gears in and they recommend that you change your fluid after 500 miles. It's been just about 500 miles. So my question to you guys is, is it okay to keep driving over the 500 miles until I get my new covers to do the change or do change the fluid now and basically "waste" 4 quarts of fluid and redo the fluid change once the covers come in?
You'll be fine waiting for the new covers.
Wait for the new covers.
So just wannna make sure, this fluid is okay to use right? View attachment 268927
Yes. As long as you don't have a limited slip differential.
I don't know if I've got limited slip or not but this stuff says limited slip on it so I assume it's okay to use in a limited slip or open diff right?
I missed that. Yes, that will be fine in either diff. Limited slip additive won't hurt an open differential.
