Brute
That shaft shield is a good idea...This is what these Ohlins shocks look like installed up front.
And, here are a few of the rear.
that's what she saidThat shaft shield is a good idea...
Looks like it should be spun around to me.? I mean the axle protects the front of the shaft.That shaft shield is a good idea...
I doubt the back of the shafts will ever take any significant hit.Looks like it should be spun around to me.? I mean the axle protects the front of the shaft.![]()
Haven't had a chance to test it off road but so far, for daily driving, they've made a noticeable difference in smoothing things out and firming things up. In my opinion, way nicer than the factory Fox shocks that came on our 392. Those always felt way too soft and squishy for my taste.THAT LOOKShows the ride??
What Mike said ^^^I doubt the back of the shafts will ever take any significant hit.
Is there a reasoning behind the taller bump stop tower? I’m assuming some clearance is sues with the larger engine?Now, there's one other thing that we did and that was to address the amount of up travel we have on the front of our 392. As you may or may not know, the 392, XR and even diesel all come with front bump stop towers that measure 2" taller than a standard JL and this leaves you with very little up travel. Of course, our 392 is lifted now but as would be the case with any good lift kit, it came with bump stop extensions that measure about as tall as it gives lift and so, our lack of up travel remained. Even at a full bump, we were only getting 3.25" of up travel.
Of course, our new Ohlins shocks have 5.25" of shock shaft showing and that means, with the way things were, we would never get to use 2" of it and, that's about where the internal hydraulic bump zone are. Anyway, we decided to remove the 3" bump stop extensions we had installed and replace them with ones that measure 1.5".
I should note, these spacers are the stackable ones that Synergy makes and we only installed one on each side being that the pucks are 1.5" tall. This should effectively let us use most of the front shocks, take advantage of the bump zones and still have 1/2" left to help prevent the bottoming out of the shocks.
Anyway, we'll be covering all this in greater detail in our upcoming video![]()
So, I couldn't tell you for sure why they exist on a diesel being that I don't own one but on the XR, I can only assume it's to help prevent rubbing of the 35" tires on the fenders at a full flex. On a 392, I do think it's to help prevent the oil filter from getting damaged at a full bump. If that is the case, we didn't cut or modify the tower at all so it shouldn't be an issue.Is there a reasoning behind the taller bump stop tower? I’m assuming some clearance is sues with the larger engine?
I’m thinking in a two door you’ll have a shot if you can keep it straight.Now that it's lifted and bigger tires. How does the 392 feel compared to the 6.2L L86 in Moby? Need to know if I pulled up next to one on the road if I have a shot at it![]()
From every thing I can see with mine, for the diesel, it’s to keep the differential out of the oil pan. It’s really, really close when bumped out. I had the same problem with bumpstop and only used 1” for the over 3” of lift. For me it works perfectly. It wasn’t as bad as my diesel JT but this one would hit the bumps when it was stock on a speed bump.Is there a reasoning behind the taller bump stop tower? I’m assuming some clearance is sues with the larger engine?
I think this is it. And it sucks. I bottom out on the stupidest things. Railroad tracks and speed bumps hit hard.From every thing I can see with mine, for the diesel, it’s to keep the differential out of the oil pan. It’s really, really close when bumped out. I had the same problem with bumpstop and only used 1” for the over 3” of lift. For me it works perfectly. It wasn’t as bad as my diesel JT but this one would hit the bumps when it was stock on a speed bump.
You can kind of see how close it is in this pic. This is with factory coils and 2.5“ spacers and no Bumpstop. Testing.I think this is it. And it sucks. I bottom out on the stupidest things. Railroad tracks speed bumps hit hard.
I think the 392 pan is pretty close too but I’m not lucky enough to see it in person. LolWe put the 1/2 Clayton Off-road springs in the front of our Gladiator and it helped this quite a bit. Raised the front about .5 and has reduced the bottoming out greatly. It also firmed up the ride nicely. Prior to installation the front would bottom out all the time just like you have experienced.I think this is it. And it sucks. I bottom out on the stupidest things. Railroad tracks and speed bumps hit hard.
What really annoys me is that we have a Tazer on our 392 and I'm pretty sure I... as in me, could have turned off the reconnect functionI guess it’s safe to say you guys are putting them to the test! The Shocks and Rancho lift haha that’s definitely the downside to the e-disco that always annoyed me. Glad to see you guys are out and back at it!
