jkt777
Installed Lux rock lights nice easy install very happy
Sent from my SM-G892A using WAYALIFE mobile app
Installed Lux rock lights nice easy install very happy View attachment 354246View attachment 354247View attachment 354248
Had fog lights installed
Many thanks to WJCO for helping out with wiring questions [emoji106][emoji106]View attachment 354357View attachment 354358View attachment 354359
Nice, did you have to drill or reuse a bolt to mount the bracket?
Finally gave the JKU a bath. Hasn’t been washed in months and was starting to grow things [emoji51]the JT is next.
Surprised you can go months without a wash there, isn’t the air salty?
Finally got around to cutting off the old control arm mounts, the new Artec ones are so much beefier. View attachment 354373
And replaced the track bar with another OEM one I found on Craigslist.
What’s wrong with the stock control arm mounts? Looks about normal... [emoji23][emoji23][emoji23]
I really should have welded some skids on before they got bent.
^^^This^^^I believe on the JK you will go through rear brakes sooner than fronts
Yeah mine were the same way. Was metal on metal when I changed them at 44k miles. I had just bought pro grips so it all worked out.Thanks for the heads up.
Those rear pads were literally falling apart......not good !
Ddays PA44 is all cleaned up, repainted, and ready to be installed. Also big shout out to Dynatrac for hooking me up with a new diff cover sticker. Looked funny without it.View attachment 354408View attachment 354409View attachment 354410
