I think these lights together are only about 3 amps. I was thinking a direct lead off of the OEM back up lights wouldn't hurt anything. Maybe put a diode in the power line coming from the Central Command to the new lights and a diode in the piggyback wire I run from the OEM lights to the new lights just to make sure there is no back current in either direction? With respect to a diode, does it need to be the same (or larger) amperage than the lights would draw, (so one 3 amp diode for each line would work?)
Thoughts?[/QUOTE]
As long as you are ok with the new and old lights running when you manually turn them on then I don't see any need for a diode. And any power back feeding to the central command when you engage reverse will only go as far as the relay because that terminal will be dead at the time.
Sent from my iPhone using
WAYALIFE mobile app
