The Ultimate TRUE TIRE SIZE Database
Dale72
I'm sure people break stock axles with stock tires as well. And I know who you are, I watch your channel, that's why I'm asking. Not sure why you are being facetious.
It seems that your mind was made up before you asked the question. And you don't want to listen to people who are trying to save you from breaking your jeep so go ahead and do what you want. Have a wonderful day
nbunga
I’m running 39” KM3s on stock Dana 44s. I’ll admit they are too much tire for how I use my Jeep. Pretty sure I bent my front axle (either the tubes or c’s, not positive.)
I knew they would probably end up being too much for the axles when I bought them though.
Of course I may have been looking for a reason to upgrade axles too.
BaddestCross
It's not the height per se, but what that height brings to the table... More weight, more stress, etc. Anything over 35s, and probably even 35s, you should be reinforcing the axle Cs, upgrading to chromoly axle shafts, regearing, upgraded ball joints. Over 37s, you should be looking at aftermarket axles for sure, especially if you do any wheeling.
wjtstudios
I like your thinking 🤣
DirtHeadDavis
And I'm not sure why you need to ask at all if you're in fact sure people "break stock axles with stock tires." Sounds like you should sell your Jeep and buy something else without solid axles and ask on their specific forums if you can run 39" KM3s.
And where the hell are you coming up with your responses? Every single tire is not made true to size - but smaller. And they get even smaller with the load of a Jeep on them. As Eddie said in his OP on this thread, everybody goes by the sidewall. That's all you need to know. But on the other hand nobody is stopping you. It's your Jeep. And if you actually do "know who Eddie is" and actually do "watch his channel" you'd know more about this then. Have a good day 👍
2020 JLURD
It isn't made up, hence the questions. I'm new to Jeeps.
2020 JLURD
Thanks for the information. Are you doing a lot of off-roading? Rock crawling?
2020 JLURD
Thanks for the valuable information. I'd like the think that jeep made the D44 strong enough to handle an upgrade on tires, but i guess it depends on the terrain that you take it on.
2020 JLURD
Well, people will always try to push the limitations to see what they can do before stuff breaks.
Like I said previously, I understand that people go off the sidewall when referring to sizes.
