swampdog
I owned a scuba repair facility for 30 years and consumed over 14,000 O-rings per year...
I have to assume that caused some serious constipation issues. Did they pass fairly easily?
That was my understanding.
Apparently Evil knows something you and I don't.
I wasn't going to say shit :dont_tell:
Check this out though. This is not the actual pic of the sway bar but just for reference. I need to dig through my old phone to find pics of when it was stock and starting to put the lift on but same point.
The stock sway bar would only go this far and stop.
Now that the air line is hooked up and it works as I hoped, the sway bar does not stop any where.
So, what "stops" travel....bump stop and limit straps? If the stock bar limited on the up swing, without that stop there, the bar does a complete loop?
Maybe in not understanding the geometry and dynamics at work hear, but this thread has been informative to say the least.
Don't know. Trying to figure that one out myself. Dealer didn't know either. My issue and the reason I went with the EVO disco was because my suspension travel was limited by the sway bar. The syspension would only flex so far before the sway bar stopped it from achieving full travel.
How is the sway bar limiting your flex? Links too short at full droop?
When the sway bar was disconnected, it would swing up as normal then stop, like it hit a internal stopper or something. Not touching any part of the frame, links are good. It did this with the links connected and just by unlocking it, removing the link and moving the sway bar by hand. It hit that certain position and just stopped.
The sway bar moves down when disconnected.
A quick photo I found. RayDon flexing!
I get it but go look at the other side. Droop, down travel or the likes the sway bar will point and go down but the up travel on the other side, the sway bar is going up.
I've never had a problem with my sway bar restricting my up travel. I'll take a look at it next time I can.
I get it but go look at the other side. Droop, down travel or the likes the sway bar will point and go down but the up travel on the other side, the sway bar is going up. When disconnected the sway bar should move both up and down freely.
Sway bar links look too short and good chance of the sway bar flipping which is not good.
