Up next is what the pin looks like with the actuator off. I didn't take a pic of it when it was dirty but once you pull the stock actuator off, clean out the gear case real good and put some fresh grease in it. The big circle with the grease around it is what moves the forks that unlock the gears, So air goes in to pin, pin pushes in that pin in the case, sway bar goes loose. I used a combo of 99% alcohol and brake cleaner to get this thing shinny.
A light coat of oil on the o rings and a very thin coat of grease on the actuator pin, some more grease to help hold the o ring that seals the no limits to the gear case and its ready to bolt on, so I thought. Its so fucking hot in my garage I had to freeze the o ring to shrink it a bit. It took a sec but its on and sealed up.
Quickly before the o ring heads south, make sure the pin is in, the bolts line up and lock it down.
