Slimebones
Thanks Doug.
So far I have only used it on 110. I tried the 220 outlet in the garage, but it is dead. The breaker felt funky, so it may need replaced, or there may be more issues, I'm not sure.
I got 0.35 wire, and could not dial it down enough to do some work on thin sheet metal. I think I will get a roll of 0.23 and try that.
I did build a couple of tools out of 1/4" square stock, and the lowest setting it will go to with the 0.35 wire, which was 80 amps. It worked good, but I had to go in short spurts, as it was really overheating the metal.
I'm also going to try it out on stick, with some 1/8 7018 rod, then later add gas to it for solid wire. It is set up for that.
That's a real plus to be able to use 110v on 1/4" stuff.
jeeeep
Yeah evap has been replaced a couple times. Last was by the dealer and it hasn’t really been driving since replacement. I’d be interested in seeing your leak.
this is what was causing my small leak code - the fitting felt tight when I checked it but it was only because it was dry rot stuck along the bottom
once I removed it, I could feel how loose it actually was on the fitting.
the hose clamp is working for now but I plan to replace that piece of hose when I replace the water pump
OverlanderJK
Resident Smartass
Think I may have found the issue. I think this nipple was broken off. Drilled it out and glued it back together. Once it dries I can reinstall the tank and see what the deal is.
-AINOKEA-
Wow. Any chance of just getting another one instead of glueing it? Would be a pain to reinstall and it doesn’t work because of a glue failure or something.
BaddestCross
jdofmemi
Do you even crossmember bro?
That's a good one. First one I have seen bent as bad as mine was. My transfer case was smashed hard against the top of the tunnel. I think the stock ones are made of tinfoil.
All the time and money at the dealership, you would think they would have found that.
jeeeep
that little bastard piece seems to break on a lot of tanks. what glue did you use?
my buddy's broke on the same fitting, tried gluing it back but broke when he put the hose back. he found a decent replacement unit at a junkyard.
will be interested to know if it holds when you put the hose back on.
