The Adventures of Fiona - '08 JK Rubicon 2-Door
BaddestCross
Got started on installing the EVO Rock Stars that have been sitting in my garage for months... Figured I'd install the coil spacers and control arms while I had everything apart.
Well, all was going well with that plan until I went to swap in the first lower control arm. The jam nut is so fucking tight that I couldn't get it loose to adjust the length. I don't have anything in my garage to hold it while I try to get a breaker bar on the wrench so I tried with it on the Jeep but the Johnny joints flex too much. 😠 To top it off, I had a pinched nerve in my back that affected the muscles in my arm so I'm not at 100%.
I don't suppose anyone has any ideas on how to get these things loose or anyone local have a good shop setup that could give me a hand?
You need a big ass adjustable wrench. The one I use is about 2 feet long. It says China on it but hasn't failed me yet. As much as I wanted to get a quality brand, they're extremely expensive. Here's the one I got:
And here's a random web pic I found of someone holding one. They're huge but they work.
BaddestCross
BaddestCross
What happens when an Irish Pollack tries to install EVO Rock Stars? A lot of cussing, blood, and whiskey, that's what! 😂😂
After a week of intermittent work, they're finally installed! Part of the trouble was me being an idiot, but the rest was some really fucked up LCA brackets that needed A LOT of grinding and bending into submission before I could get the new sleeves to fit and everything lined up.
While I had the rear apart, I took advantage of it and reinstalled the 1.75" coil spacers, replaced the adjusters on my Rancho 9000XLs, and flipped the shocks 180° so the fucking knobs shouldn't break off again. 👍
I found that the joints on the sway bar links are shot, so I'll be needing a new set... How is the sway bar supposed to be lined up to the frame? About 5° off like the front? If so, I'll need to get longer ones.
BaddestCross
Good work! They are a pain to install but it's a nice addition.
Looks good. :thumb:
Nice [emoji106]
US Army Combat Vet. Afghanistan 2010-2011
Looks good, I like the red!
Thanks guys. 🍻
Yeah, "a pain" is an understatement. I love how Eddie's write-up makes it look like a 10 minute job. 😂😂
dillard09
Nice work! The rockstar look bitching! I know you had those for awhile cause we were going to put those in back months ago when you came out to my place for the install party! Finally!
BaddestCross
Right? Finally! Yeah, same ones I had back then. 😂😂
Now that the bday party is off maybe we should go run the Miller Jeep trail before they close it for the winter so I can test out the upgrades. 😎
BaddestCross
Really fucking happy with the results of all the work I put into her... I haven't taken her to the rocks yet, but I did get to blast down some shitty washboard roads tonight. Same road before I had to go 45mph or less otherwise it would rattle the teeth out of your mouth. Now, with the axle off the bump stops I could soften the Ranchos a couple notches and she rode like a cloud at 65-70mph over the same road! 👍
