Hope this helps. View attachment 150137View attachment 150138
Did you use the mounting plate and bolts or is it just wedged it in there?
The switches we use are rated at 100,000 cycles so they are very reliable. It is very unlikely that one would go bad. We give a life time warranty on the switch panel so there is nothing to worry about.
Just putting this here as well just for anyone's reference....here's how I mounted my switches in my 2015.
The holes lined up about 98% perfect and since its plastic the little bit of play made it work fine. The speakers is just barely covered by the pod, and doesn't affect playback or volume at all.
Nice spot. Any way to tuck the wire into the speaker grill?
Anyone else have the switch panel mounted on a Daystar panel in front of the shift lever?
I haven't seen it, but it's not a bad idea. I just don't like the daystar panel on a 2015 - for a 2007-11 or so it would probably be a great option.
Curious why you don't like it on the newer models?
Got mine yesterday from NR4x4. Very excited to get it hooked up. Question for switchpro. Can you make some labels for vertical mounting? Since they are rectangles seems to only mount horizontally.
Thanks
