Dibs on the used bolt on kit!!!!
Just kidding.
:cheesy: If you change your mind, let me know.
BTW, you should have joined us on our kick off run last Sunday. Hope you can make it out to one of our upcoming runs too.
Just kidding.
Can you run 40's with the full Bolton kit? (Non Evolever)
We Are Jeep..Resistance Is Futile..
Can you run 40's with the full Bolton kit? (Non Evolever).
Why couldn't you?
JaySC on here is running bolt ons and 40's.
You can run 40's yes. Your axles and DS are what need to be beefed up for those big tires. I know you've got a 60 waiting to be installed right?
And trust me when I say this Lee, you will not regret going with the EVO bolt on Coilover setup vs the rebel! :yup:
I wasn't sure if Evo's kit would sit too low or not .
Is there such a thing with coil overs? If anything, it's hard to get them to not be so tall and the Rebel kit is proof of that. The EVO brackets will allow you to set your coil overs to about 3" of lift. I have mine set at about 3.5" to clear my 37's and would only raise them about an inch to clear 40's. I'm pretty sure that the Rebel kit can't be set any lower than 6"+.
I'm hoping to avoid having to use a body lift, if that's even possible. Just don't care for the way they look.
Why would you need a body lift? I mean, if you really wanted to, you could set your coils overs to sit pretty much as tall as you want. if you want to go even taller, you could get coils with a heavier spring rate and sit way taller than a Rebel kit. :idontknow:
Coilovers are a whole new animal for me,Eddie. That's why I'm asking questions that may sound newbie-ish or stupid, lol.
It's all good. You just need to look at coil overs as being two different coils, one stacked on top of the other and with a shock going through the middle of them. This shock is what the coils are mounted to and the shock is mounted on the frame on one side and the axle on the other. Now, try to imagine that down the length of the shock tube, you have threads where a collar is threaded on. This what the upper coil is pushing up against and, depending on where YOU position that collar, up high on the shock body for a nice low stance or, down low on the body for a sky high stance. You know how a budget boost works right? Basically a spacer that sits on top of a coil to give you about 2.5" of lift? Well, the adjustment collar on a coil over shock body is kind of the same thing. Depending on where you position it, that for the most part will determine your height.
Does this make sense?
Now I know how coil overs work. :doh:Thanks. I would love to drive a Jeep with this setup to see if that is something I really want.It's all good. You just need to look at coil overs as being two different coils, one stacked on top of the other and with a shock going through the middle of them. This shock is what the coils are mounted to and the shock is mounted on the frame on one side and the axle on the other. Now, try to imagine that down the length of the shock tube, you have threads where a collar is threaded on. This what the upper coil is pushing up against and, depending on where YOU position that collar, up high on the shock body for a nice low stance or, down low on the body for a sky high stance. You know how a budget boost works right? Basically a spacer that sits on top of a coil to give you about 2.5" of lift? Well, the adjustment collar on a coil over shock body is kind of the same thing. Depending on where you position it, that for the most part will determine your height.
................. Does this make sense?
Man, I'm new to all this and maybe a lot of people already know these things? But, your last two posts really clearly and simply explained the coilover.
I knew there was a ring you could dial in, but really didnt understand the tech behind it. Great couple posts!
And a picture to boot!!! That really helped.
