Random Photos
black pearl
Thanks. It’s saving time, and that was the main reason I bought it. If you are looking at one, there are things to consider.
Does it need to fit through gates? If it doesn’t, get one with the largest tires available, for the size deck you want. Regarding deck size, you won’t necessarily need a wider deck, to cut in less time. The turning radius, and drive speed are what makes the difference.
If money is no object...Scag is the brand to buy. It cuts cleaner than anything. Although I thought Hustler was a new brand, it isn’t. Hustler produced the first zero turn mower ever made, in 1964. They are pretty good mowers. They are well built.
Great information. My big thing is durability. Some areas of my property are on the rougher side, but also the areas I can’t get my tractor. So ground clearance is also a concern.
Money is always a object I have a Jeep to support 🤣
notnalc68
That dude from Mississippi
Skip most of what is sold at the big box stores, then (Craftsman, Cub Cadet, etc.). Look for fabricated decks, and string frames. Lots of them are available with Kawasaki engines, in the homeowner versions. Look at Hustler, Big Dog, Snapper, Grasshopper, Kubota, Scag, eXmark...
OverlanderJK
Resident Smartass
Disclaimer: this is hard to show in pictures.
So I was working on the DJ yesterday and needed a 7/16” socket. Was using a 3/8” drive and then grabbed my half in drive. Turns out the 7/16” half inch drive socket is actually a 1/2” socket.
Three sockets together (L to R, 7/16” 3/8 drive, 7/16” 1/2 drive, 1/2” 1/2 drive)
7/16” 3/8 drive socket
7/16” 1/2 drive socket
1/2” 1/2 drive socket
Looks like one was misprinted. Ive reached out to tekton this morning. I’m sure they will make it right. Can’t say I’ve ever seen this on any tool I’ve bought before.
jdofmemi
That's odd. I've never seen that either.
So the question is, how many bolts got rounded off as you figured out the problem?
Pretty sure Tekton is still using the same impacts as harbor freight so not too surprising.
notnalc68
That’s nuts. They will probably warranty it.
