Exodus 4x4
I don't get why everyone has to be a Johnny storm cloud and hate on everybody's shot for no reason.
Because you're wrong and your stupidity doesn't need to infect others.
the idea of the initial post was lift ideas so i tossed in my opinion which I am entitled too and y'all piranhas attacked it like you designed the jeep
I'd be willing to bet most people in this forum buy parts and pay shops to put it all on
Go measure your caster right now on level ground and tell us what it is.
Well it's working and it has been....so there goes your opinion
My caster is exactly the same as it was the day she came off the line, brake lines should be done but are not necessary unless you plan on hardcore wheeling, and the front driveshaft can be extended far further than a 6in lift will allow for without putting any unnecessary stress on the u-joints. I think someone is sour they spent a fortune on their jeep and got nowhere with it.....
I cant even do this thread anymore...
Rough Country or Zone lift for my '15 JKU? Looking at maybe 4 inches and wondering what everyone thinks...... Go!!
Better yet, go have someone else that actually knows what they're doing measure your caster.
I can tell you right now that you are wrong. I have a 6.5 inch lift and left the driveline completely stock. I had to remove my front driveshaft because it was about to shear itself apart and I wasn't even using 4 wheel drive. Even if you changed your pinion angle the front driveshaft is maxed out so one significant droop of your front axle and bye bye shaft. The rear yes, I am still running my stock rear. But the front is a no go. You sir, your witchcraft is flawed.
Savage,
You said you have 3-4 in of droop before your brake lines get tight. Which means you have 3-4 inches of flex correct? Not busting your balls just making sure I understand you correctly. If that's the case than the only trails that rig could conquer is the occasional curb in the mall.
Closer to 87 in front and 86 rear, that's in my garage, however level that may be
I'm looking to spend about 2500 lift, wheels, and tires all included
This is the first lift I have done. That's why I am asking for advice. I do appreciate it. I was wanting to go 4 but u guys are making sense. That's why I came here first. If I get the budget boost do I also need the leveling kit?
