Hinrichs build
hinrichs
My only useful suggestion is use a step bit when drilling for the switches holes. They are kind of a strange size.
Ill have to remember that, and find the one I have.
So im torn between the warn vr10000s and the m80000s....cant figure out which is better
hinrichs
So happy with my lift and tires since I finally had the chance to get offroad with it. Still want 37s but need to figure how much I'll need to upgrade. Didnt take many pics but here are some I have, basically got it really muddy which still havnt gotten to clean off yet.
JKAnimal
Looks like you guys had a fun time! Jeep is looking good :thumb:
hinrichs
i like the soft 8 style they have. i would get em and then get your 37's. it will hold the bead (per eddie) with the narrower rim just fine so you will not need the bead locks
Well for me right now im sure id be fine, i can always have a shop weld rings on the steel wheels anyway if i want beadlocks. I just want to save my oem wheels from being beaten up as bad and also put my stock tires back on incase I ever need them.
big thing is to go with the 4.5 offset or the 4.25....just dont want to get hassled for my tires sticking out
Tackerdown
Banned
One of the reasons I got the c.o.d. package was for the wheels. I wish I would have thought ahead,now they are past the point of no return.:(
EVO 4G WAYALIFE.
hinrichs
Sweet, I'm really happy with how mine did.
I was going to go with warn, but after seeing yours twice and having been pulled out myself I thought why not just save some money, plus they have the same warranty. Now wondering if I should upgrade to an optima battery or stick with the stock one to see how long it lasts.
Lane87
I think the only battery troubles you run into is when you're actually using the winch.. I could be wrong though..
cozdude
Guy with a Red 2-Door
just stick with the stock one. if you end up getting more accesories or start using your winch a lot then i would upgrade. no need to ATM tho. :twocents:
Lane87
I got the yellow top because I had my stock battery replaced in korea and it was the wrong size.. it worked fine for starting but i didn't trust it otherwise.. also I could be crazy but I swear my headlights are brighter now with the Optima..
hinrichs
delivered in a day...it was in stock in their other warehouse which is in chambersburg...also ordered some battery terminals which wont be here till friday :thinking:.....when i get home i may end up re routing the wires as well for it
