mds22
You bent the tailgate because you either didn't have the tire pressed tight against it or you dropped off a ledge and hit it. Those are the two ways wheeling would bend it. It's not because the gate is weak.
This ^^^ just keep it pressed tight.
I was told I should take it off when I wheeled. But found that to be BS as long as it's tight and doesn't jiggle. I did add an extra bump at the bottom to be safe b/c I had to raise up the mount to clear my rear bumper.
