gtony12
I have 9,000 miles on mine and its only 6 months old.:crazyeyes:
My JK is 7 mos. old 16,882.1 on it and was in the shop for 8 weeks of that:rock:
Not to hijack any further, but I put 3300 miles on my car two years ago. I've put almost 20K on my jeep in 16 months!
Know what. If you don't drive it, what go is it. I drive it because I love it "Jeep"!!!! :wings:
40s on a stock front end is just too much. Even if you sleeve & gusset! I did everything but truss it and the right side tube still bent! And I'm only running 37s. Yes the Dynatrac is the way to go, I've got my front already and saving for the rear. Anyone want to buy a good used Kidney?:cheesy:
2-1/2 years?? LOL!! I can put on 12,000 on each of our JK's in about 2-1/2 Months and I work from home :crazyeyes:
So back to 40's which brand do most people run and why
Depends on what you need them to do. If you want to play hard on the trails, few 40's can compare to a Nitto Mud Grappler. If you're looking for a good all around 40, I would recommend a Nitto Trail Grappler or Toyo MT. I've run them all and they have always served me well. If you need something that'll last a long time, BFG's will wear like iron but, have really thin sidewalls.
No, I have no experience running them. I believe that the company Nemesis was running a set on their JK last year at the King of the Hammers clean up and tore through a sidewall. ProfessionalDriver was there and I'm sure he can verify as much.
Ok how about brand, I see a lot of the big named guys running a 37 and AT when they drive across the states. Is there certain 40's are as good?
I'm considering Toyos, GY MTRs, KM2, or Nitto's
Scratch the Goodyears and KM2's from your list of 40"s. The MTR/K's are a true 40" tire, however they are barely able to be balanced because the tire is almost a square, and have exceptionally weak sidewalls. The KM2's although overall not a bad tire, their sizing falls very short of the claimed size (almost 2" on some sizes) and the KM2's sidewall also leans towards the weak side when compared to the Toyo or Nitto's. KM2's also are not very good in the snow/ice because they have zero siping. I have owned all 4 of your choices, I personally will have hard time moving away from Nitto (and Toyo since it shares the same parent company, and even factory for some tires).
