We-B-Jeep-N
Looks great.
Sent from my iPhone using Tapatalk Pro
Great write up! Hope I followed it correctly, and don’t have a leak!
Looks great.
Nicely done :thumb:
So I got regeared a few weeks ago and the shop said to change the oil after 500 miles. So today I did that and I couldn’t get but maybe a quart and a half of oil in the rear and it calls for 2.375 quarts. Seems like the amount I got in the rear was the same as the front. Any suggestions as to why I can’t get the right amount of oil in the rear. Front and rear are both rubicon Dana 44
You may be alright. If fluid dropped out of fill plug, you're good. There area lot of cavities within the locker, etc. Also, if you weren't on even ground, some of the oil may have been running into one of the axle tubes on the rear. Check it in a day or two and see if it changed. Also, if you were parked on an incline, the fluid level won't be accurate.
Ya I was just slightly uphill and it started coming out of the fill hole. Ok great I’ll check it in a few days, and thanks.
What WJCO said. I couldn’t get quite the full amount in, when I had the factory cover. Drive it a little, and check the fluid levels.
I've done two fluid changes now on my Rubi 44 with stock cover and both times I could get barely a quart and a half in. I was level, drove it around, and rechecked it. Still spilled out of the fill hole so I don't think I could get anymore in. Called it good and it's been fine. I felt the same way after my first one. I was worried and made a big mess trying to get as much oil in as I could...hahaSo I got regeared a few weeks ago and the shop said to change the oil after 500 miles. So today I did that and I couldn’t get but maybe a quart and a half of oil in the rear and it calls for 2.375 quarts. Seems like the amount I got in the rear was the same as the front. Any suggestions as to why I can’t get the right amount of oil in the rear. Front and rear are both rubicon Dana 44
I was walking by the jeep today and noticed the rear diff was wet and a small spot on my concrete.... I'm guessing the cover got deformed a little from hitting some rocks... I have about 12k on my 2017 JKUR.... And I know I don't need to change the oil until 15k.... but it might be a good idea to get stronger covers installed before I regret it.
1. I'd like to use Dynatrac Covers.... any cons to this?
2. Which is the best Gear Oil to use.... Standard Non-synthetic 75W90 Per Eddies instructions? Any Particular Brand you guys Prefer?
Thanks
1. No cons. Great cover and what I prefer to use if only because it's made by Dynatrac.
2. Any brand will work just fine. So long as you're still running factory lockers, synth is fine but if you're running ARB's, you really want to use dino.
I'm Still running factory Lockers.... Going to pick up some Permatex Right Stuff and the Gear Oil.... do you have the Covers on your Amazon Link? I didn't see them....
O'Reilleys or Walmart has gear oil cheap. I try not to cheap out too much with Jeep parts, but gear oil is gear oil. Even the cheap shit has to meet sae standards and it gets the job done.
I actually have some Valvoline 80W90 that I used in my Ford 9" on my truck.... is that ok, or better to stick with 75W90?
The one thing I don't like about Dynatrac covers is the lack of a drain plug.I was walking by the jeep today and noticed the rear diff was wet and a small spot on my concrete.... I'm guessing the cover got deformed a little from hitting some rocks... I have about 12k on my 2017 JKUR.... And I know I don't need to change the oil until 15k.... but it might be a good idea to get stronger covers installed before I regret it.
Thanks
On a factory gear ratio, I bet either would work OK. No limited slip clutches I assume?
