What's in your Jeep tool kit?
Gonna give this thread a bump as I go through my stuff and put it in the new Jeep. Some stuff still missing as I have recently ordered to replace broken or haven’t packed yet. No spare parts included.
Air Up/Down Bag
-Air Hose
-Blow Gun
-Currie Tire Deflator
-Air Pressure Gauge
Bottle Jack Bag
-12 to. Bottle Jack
-Large C Clamp
-2.5lbs Sledge
Misc Nuts/Bolts
Tire Repair Kit
Sockets
-Full Metric Set
-Full Standard Set
-Hex Set
-Torx Set
-Extensions/Adaptors
-36mm
-Ratchet
Electrical Bag
-Terminals
-Small Nuts/Bolts
-Hose Clamps
-Cotter Pins
-Wire
-Spare Fuses
-Banjo Crush Washers
-Brake Bleeder
-Electrical Tape
-1410/1350/1310 Ujoints & Strap Kit
-Tape Measure
-Wire Crimpers
-Suction
Wrenches/Torque Wrench/Screwdrivers/Misc
Fluids
-Oil
-Power Steering Fluid
-ATF+4
-Brake Cleaner
-Brake Fluid
-Speedy Dry
-Oil Filter
-Funnel
-Diff Fluid
-Pump
-2x4
Interior Cubby
-Spare Belts
-4x4
-PSC Hoses
-Radiator Hose
-Brake Lines
-1 7/8” Wrench
Recovery Gear
-Tow Strap
-Tree Saver
-Shackles
-Chain
-Hitch Tow Point
(Missing - Snatch Block, soft shackles)
All Packed in
All together it’s 188 pounds of shit. That doesn’t include spare parts and tools that are missing that will be here this week.
That's a good amount of stuff. Do you hear the nuts and bolts bouncing around in those plastic cases?
That’s a great list! Going to use this as a reference to double check my shit. Thanks for posting this.
What size ammo box is that and what is the 1-7/8 wrench for?
Looks like a 50cal ammo can. Same one I use.
It looks a lot larger than that. Maybe a 40mm?
7.5”Wx14.5”Hx17”L
If you can read this, this is all the writing on it.
I’m sure I would the way they are now. They will be tight in there though before I go out. They were under my custom built deck in the two door and it was a tight fit and I didn’t hear them.
I like the Deck....I did something similar with L brackets and love the fact I dont hear shit under it, but I don't carry near as much as you yet!
I put a grip mat on top and hooks for tie downs since then.Screenshot_20190520-210304_Photos.jpgScreenshot_20190520-210311_Photos.jpgScreenshot_20190520-210316_Photos.jpg
Air Up/Down Bag
-Air Hose
-Blow Gun
-Air Pressure Gauge
Bottle Jack Bag
-12 to. Bottle Jack
-Large C Clamp
-2.5lbs Sledge
Misc Nuts/Bolts
Tire Repair Kit
Sockets
-Full Metric Set
-Full Standard Set
-Hex Set
-Torx Set
-36mm
-Ratchet
Electrical Bag
-Terminals
-Small Nuts/Bolts
-Hose Clamps
-Cotter Pins
-Wire
-Spare Fuses
-Brake Bleeder
-Electrical Tape
-Tape Measure
-Wire Crimpers
-Suction
Fluids
-Oil
-ATF+4
-Brake Cleaner
-Brake Fluid
-Speedy Dry
-Oil Filter
-Funnel
-Diff Fluid
-Pump
-2x4
-RTV x3 tubes
Interior Cubby
-Spare Belts
-4x4
-PSC Hoses
-Radiator Hose
-Brake Lines
-1 7/8” Wrench
Recovery Gear
-Tow Strap
-Tree Saver
-Shackles
-Chain
-Hitch Tow Point
-Snatch Block
(Missing - soft shackles)
All Packed in
Added a snatch block, first aid kit, RTV, and some small wrenches/ratchets for a shock tuning kit that is in the glove box.
Awesome . I actually carry most of that stuff hah . Need to add the huge wrench for the jam nuts, a c clamp, the 2 radiator hoses I bought I haven’t installed, and some spare bolts .
Thinking the 2 spare front axle shafts I carry between the rear seats and the Tuffy aren’t necessary — unless on a several day trip — there’s 50 lbs right there
