Yes, I had the same issue.  1st make sure they are torqued. Your clunk is most likely coming from the bottom of the links.  There will be a little play because of the cotter pin.  Go purchase some thin rubber washers from Home Depot and cut them to fit your lower disconnect bolt.  You will need 2 rubber washers, 1 for each disconnect.  I also spray some WD40 on both ends every couple weeks just to keep everything lubricated.
