Rock krawler clunk
Ah2014jk
Any fix for the quick disconnect clunk fron Rock krawler quick connects ( other than go buy JKS )
Yes, I had the same issue. 1st make sure they are torqued. Your clunk is most likely coming from the bottom of the links. There will be a little play because of the cotter pin. Go purchase some thin rubber washers from Home Depot and cut them to fit your lower disconnect bolt. You will need 2 rubber washers, 1 for each disconnect. I also spray some WD40 on both ends every couple weeks just to keep everything lubricated.
Mine are the same way and torqued to spec. There I believe were rubber washers that came with them from rk but they don't seem to do anything
