Take a look at your owners manual. There should be an ambient temperature graph. Unless you live in a desert, heavy towing, or you're starting to have low oil pressure issues, pretty much stick with 5w-20. The tolerances inside the newer engines are much tighter than in the past.Was just reading a thread where most of the guys have switched from 5w20 to 5w30 in their 3.8's, gonna change the oil in my wife's 2010 with 81k this weekend and wondered if this would be a good idea on someone else's jeep?
I have 5W-20 in there. Could that be why my temps are climbing lately? How much of a difference if I switch to 5W-30?This^^^ I know for me my summers get really hot and 5-20 just gets destroyed. Switched to 5-30 for summer due to being able to take the heat better but come fall I will have 5-20 again
51k milesEngine oil isn't just a lubricant, it is also a cooling method. Coolant and the oil remove heat from the block. Depending on how hot it's been for you in your area, how old you oil is, and how old coolant is can all play a factor.
How many miles are on your Jeep? Still oem coolant? Last oil change?
Temp gun is the key here. Engine oil coming out of traffic in Denver (looked at your profile, I'm not stalking you I swear) should be under 200*f. 220*f is a max. 240*f is kaboom. Just temp the oil pan and see where you're at. Also, with you being where you live, don't confuse heat and humidity.51k miles
Coolant is OEM but I top it off from time to time
Last oil change 1k miles ago
Not too tight. Just 18 ft lbs. You'd be better off using an inch pound torque wrench to do this. I typically just tighten until snug.Thank you for this informative post.
One question - how much should the new filter be tightened?
Thanks!
Thank you!Not too tight. Just 18 ft lbs. You'd be better off using an inch pound torque wrench to do this. I typically just tighten until snug.
