Kmc or dirty life?
Tallon713
I'm looking at some bead locks, kmc km 233 hex or the dirty life 9302m road kill.
What would you experts say and why? New to this, so any help is appreciated!
Ddays
They're both nice wheels, but if I was picking from the two, I'd probably go with the KMC's. I've never run KMC's but have run ATX Slabs and Chamber Pros in the past, which are from the same parent company, Wheel Pros. Hard to beat their quality.
KevinG
Another vote for the KMC. On my second set of machetes, the only reason for two was for 3 more lug nuts. The Hex look pretty nice, very "slab"ish. but with drain holes in the rings!
Bear_JT
I had the Dirty Life Road Kills in non bead lock on my JK. They are a good wheel. The one thing I would say is the finish i.e. color could slightly vary. Other than that, they were a decent price, very strong and look good.
fiend
Wheels are largely an aesthetic choice. I.e., pick the one you think looks the best. If you actually wheel and expect to rub the wheel on rocks, etc., then consider ring thickness and also whether the ring bolts are recessed. Some wheels have thin rings that flex. Others have bolt heads the stick out and can get chewed up.
I would add that some wheels come with smaller diameter bolts as well and I have seen them break.
DirtHeadDavis
Another vote for KMC here as I've always been partial to their styling and overall look, as well as functionality. Quality is hard to beat IMO.
treys1
Love my Hex's. I actually wish they made them in 17" 8x6.5 so I could run a set on my CJ as well.
Tallon713
Thank you all for the information. I'm glad I asked but am now at a stand still. Was going to after the kmc hex but the bolt heads stick out. I've done some rubbing on my wheels and am afraid that I might mess up the bolt heads now. F×*k!
treys1
You are going to scratch up any bolt heads on a beadlock if you actually wheel IMO. Best to get what you like / fits and deal with it. My rings and bolts have taken a pretty good beating and are doing fine.
OverlanderJK
Resident Smartass
Well if the bolt head is recessed you won’t. Only if they are exposed like yours and some other options.
