cozdude
Guy with a Red 2-Door
For the past few months my jeep hasn’t felt like it was riding like it should. The front end felt like it was sagging and leaning to the driver side and the rear was just super squishy and not responding to the bumps in the road right.
I knew I had driven over the recommended mileage that king suggests to do an oil change (15k miles) but being on the east coast I don’t have any local places to have them serviced. That being said it would have cost way to much money to ship them anywhere, pay for the service (avg cost I found was about $125 a shock), then pay for shipping back. So I decided to dive in head first and do the service myself and learn something along the way.
What you need:
King Seal kit 21000-900 (maybe different on shocks compared to coilovers)
King shock oil- 1 gallon
Vice
5/16 Allen Head
1/4 ratchet
3/16 Allen Head
1/16 Allen key
24mm socket
1/2” wrench
Small screw driver or pick
Soft dead blow hammer
Valve steam remover (or the like)
1. Once you remove the coilovers from the jeep place it in a vice with the shock shaft sticking up.
2. Release the nitrogen from the remote reservoir
3. Grab your 1/16 Allen key and loosen the stop screw
4. Loosen the dust cap and slide up the shaft. I used and adjustable wrench and towel to remove since mine were a little stuck.
5. Next your going to see the seal cap. Push down with both hands to expose the snap ring at the top of the shock body.
Once exposed use a small screw driver and remove the snap ring
6. SLOWLY pull the shock shaft out. Oil will go flying if you yank it out really quick!
7. Dump oil out of shock body and resi into a container.
8. Place the shock shaft into the vice
These next few steps are very important! Keep everything in order and remember how it came off!
9. Grab your 24mm socket and 1/2” wrench and remove the nut at the end of the shaft.
10. Carefully take everything off and lay it out in order! You do not want to loose any valving shims or lose any parts!
11. Take the dust cap and r&r the seal.
12. So the same with the seal head.
There is also a seal in the middle of the head. It is clear and very heard to see. I missed it my first go around
13. Once the new seals are in the dust cap and the seal head place everything back on the shaft. When putting the nut back on tighten to a little past snug
-You can now put the shock shaft on the table and place the shock body in the vice.
What you need:
Vice
5/16 Allen Head
1/4 ratchet
3/16 Allen Head
1/16 Allen key
24mm socket
1/2” wrench
