Jeep Lean Fix
Something is not where it's supposed to be. Not sure how long it's been this way, but I'm pretty sure I found my lean problem.
And to make things even more fun.
Sheared off. Now let's see if I can fish that flag nut out.
I've taken measurements and much like many others, my passenger side is exactly 1 inch lower both front and back. If I got a 1 inch spacer for front and rear would that theoretically level it out and that's all I would need?
Are there any negative effects on how the vehicle performs/feels if I only add spacers to one side?
The broken bolt cause the 1.5 inch lean? I have the same set up as yours and I have same lean but I don’t have any broken bolts
I have the kings rebuilt/ new springs/everything checked and weight is even on both sides still have pass lean.
I send you a message
Yea the control arm was jammed up into the bracket. Fixing that was a little more than a 1" of the lean. I have a little different pre-load on the rear CO's. I also installed adjustable sway bar links front and rear. Fine-tuned it from there.
