Thanks. Yes I am familiar with the AGM and their price.Not sure what you mean by "quiet things down," but AGM makes a slider for coil overs. They are well-made, not cheap and arguably not necessary. 3-piece construction with a replaceable liner sleeve. I used them with my original coil over setup and they worked fine.
Dave
I'll be fine. Hearings not greatest anyway. Really just curious about these spring bearings.If there's a benefit to standard coil and springs and clevite bushings, it's that they're SUPER QUITE.
It was the broken control arm bolt.Any updates to this @Seahawkfan
Yea the control arm was jammed up into the bracket. Fixing that was a little more than a 1" of the lean. I have a little different pre-load on the rear CO's. I also installed adjustable sway bar links front and rear. Fine-tuned it from there.The broken bolt cause the 1.5 inch lean? I have the same set up as yours and I have same lean but I don’t have any broken bolts
I have the kings rebuilt/ new springs/everything checked and weight is even on both sides still have pass lean.
I send you a message
