Anvil Jeep Build - Jetlau3
danford.lau
Got the AEV rear diff slider on today . Probably the easiest install I’ve done on the Jeep . Well made . Hope it saves my drive shaft from getting beat up .
Tested mirrors . Ready for next door less trip
Fun times on John Bull last weekend
danford.lau
Spent better part of Sunday installing the evo corner armor and rear tire carrier . Thanks to Jerry (jdofmemi) for the great deal and the help on the install
Still left to do :
- new hitch pins ordered
- ordered wiring for the Maxxima rear lights (zip tied stock lights into carrier so I could get home from Jerry’s at night)
- deal with spun nurserts (will prob just cut and glue in bolt heads)
- adjust fit.. need to lift driver side up high and torque the bolts on the passenger side brackets .. right now with tire it sags a few inches
- cleanup holes we cut for lights
- ordered evo antenna mount and need to remount cb antenna
- figure out rotopax setup I will go with .. orders kC mounts and will experiment on how not to cover up license plate .
- reinstall reverse camera
Happy with this so far . Damn that was a hard install
Ddays
Still left to do :
Came out great. That carrier install isn't easy. And adjusting it can really try your patience!
rubiDave
Looks good Dan.
Still left to do :
danford.lau
Next time you come we can get it. I have a big enough Crescent wrench for it
I have a set of big ass box wrenches you can use.
Thanks both . Jerry I may be down closer to you in Fullerton the weekend of 11/6 . Will try to link up as it gets closer
Dave and I have been chatting about planning a calico trip soon now that the weather has cooled off
fiend
Good job guys. A lot of work.
Let’s all do a run soon.
Seahawkfan
Looks good. On the spinning nutsert. I had good luck with a little red Loctite around the nutsert and body panel, run tap in it to make sure it's nice and clean. Then apply pleasure to the armor while threading the bolt in. Had one spinner on my rocker armor. This worked for me.
TrailHunter
Looks Good Dan...
...could you dab a little Epoxy in between the nutsert and the panel?
