So will this kit level as well as lift? The first post shows 2" front AND back.
I think this is what I have been waiting for... I have gone from wanting the Evo Leveling kit to the Rancho sport kit (spring and spacer) and now this. I wonder exactly how much trimming would need to be done with 35" KM2's on stock rubi rims and 1.5 spacers??
What year JK?
What year JK?
Here is the info:
REAR door area on the 4 DR ( Metal right next to the rock rail on the rubi ) just need to cut that sharp piece, usually on the pre 2013.
2Dr , same area . On the front , it was around the base of the front fender and the big factory fenders.
2015 JKU Rubi.
Must have been typing while you were editing, Okay so just the little bit of metal trimming in the rear fender wells. You don't think I will get any rubbing with the stock fender flares?
So ish is shocks and springs? As in complete kit?Let's say about $75 or so than a set of shocks.
So if 4 RS9000XL are $440 add $75 ($525ISH)
If 4 RS5000X are $225 add $75. ($300ISH)
Remember ISH
Complete 2" SPORT system
What shock number comes with this kit? Can you substitute sizes if necessary, if you run rockstars?
Thanks
Sent from my BNTV600 using WAYALIFE mobile app
Hmmm, that may be the opposite of what I'd need.[emoji32]26 (stock front )
30 (3" rear)
Those are the last two digits of the 5000X or the RS9000XL
You don't think you'll drop a coil with the 30 and rockstars? If not then I'd be content, I'd just use 2" shock ext in the front and the driveshafts would still be okay.
Are the front coils the same as the Evo plushride 2"?
Rear coils only to be available for those with the old spacer rear?
