swampdog
Long story short, the switch pros control harness from the switch panel will NOT fit through the driver or passenger side fire wall opening behind the side panels. Tried 4-5 times on each side. The pinch seam beneath the side cowl blocks the opening just enough that the 4 pin connector can get through. Any other place with a larger opening that I can use to penetrate the firewall? This is fairly urgent and I spent 3 hours tonight trying to pull the harness through. I called and left VM at switch pros.
