Auto or stick? I drilled straight through the tub myself and used a waterproof cable gland.I installed AEV single compressor in the rear cargo tub but haven't found a way through the firewall to connect to the battery. Any ideas?
Sorry, didn't see that it's a 392 so of course its auto. On the auto JL's (non-392) there's a plug in the firewall below the brake booster that can be unscrewed to run cables through (you can drill a hole in the plug and then seal it up after you run your cable through, or make the hole a tight fit for the cable and skip the sealing). I'm not certain that the 392 has this plug though.I installed AEV single compressor in the rear cargo tub but haven't found a way through the firewall to connect to the battery. Any ideas?
It is a 392 so only comes with autoAuto or stick? I drilled straight through the tub myself and used a waterproof cable gland.
I'm looking to run on passenger side.It is a 392 so only comes with auto
If it's like the other JL's there is no good way through the passenger side. There's some harnesses that run through the firewall on that side but they have sealed boots on them. You can try and make a small hole in the boot and snake it through but I've read of some people damaging factory cables attempting this.I'm looking to run on passenger side.
