^^^^ ThisIf you're planning on keeping your factory shafts, you will need to make sure that you get u-joints with c-clips or modify the ears of the yokes to accept full circle clips. Me personally, I might recommend just waiting until you actually need to replace your u-joints and use the money you save to buy new chromoly shafts with full circle clips. I rarely see an instance where a blown u-joint doesn't take out the whole shaft.
And in my case it also busted out the top ball joint from the knuckle.^^^^ This
When the u joint on my JL broke it destroyed the ears on the stub shaft and the axle shaft.
And could damage the knuckle.And in my case it also busted out the top ball joint from the knuckle.
