Rancho
TL/DR
This is for the FRONT Dana 44 WITHOUT the drain plug, so mid-late 2021 and forward.
Check with your favorite retailer on cost.
Designed to protect your differential casting from direct contact in severe off-road conditions, the Rancho® rockGEAR® front differential glide plate mounts to the front axle casting of your Jeep® Wrangler or Gladiator. Manufactured from 0.25-in. high-strength steel with a durable red powder-coated finish, this differential glide plate delivers a smoother glide over obstacles.
- COMPATIBILITY -- Designed for Jeep Wrangler or Gladiator Dana 44 (M210) axles that DO NOT have a drainplug on the bottom of the very bottom of the center housing; please inspect your vehicle before purchasing
- COMPATIBILITY -- Works with OE and most aftermarket differential covers on Jeep Wrangler JL or Gladiator JT, Dana 44
- BUILT FOR THE TRAIL -- Protects differential casting from rocks and other obstacles while off-roading, rock crawling and trail riding
- GLIDES OVER OBSTACLES -- Mounts to Dana 44 front axle casting for a much smoother glide over obstacles both forward and backward
- RESISTS CORROSION -- Durable red powder-coat finish resists rust and corrosion
- ENGINEERED TO LAST -- Features 0.25-in. high-strength, low-alloy steel construction for long-lasting strength
