2007 JKU CANADA
Rugged ridge as well here.
			On my way back from Colorado the wind would get under the hood and stretch out the rubber latches to the point that I thought they would snap. I’m looking for a replacement set that will correct this problem. Ideas ?
X2! no flutter at all, even with 50 mph winds and passing a semi!
This exact thing happened to me on the way through OK.On my way back from Colorado the wind would get under the hood and stretch out the rubber latches to the point that I thought they would snap. I’m looking for a replacement set that will correct this problem. Ideas ?
I went with the aluminum Rugged Ridge latches, but also considered the Daystar. I was worried the Daystar would wear out over time as well though.
I have followed this thread as I have had major flutter issues, as most anyone has, when they pass simi’s on two lane roads (especially simi’s with irregular shaped trailers as they cause a good deal of air disturbance). My question, without re-reading the whole thread is this, has anyone ever personally experienced a true latch failure?
Remove the hood spring it helps a lot. Plus it makes Drew happy...hahaOn my way back from Colorado the wind would get under the hood and stretch out the rubber latches to the point that I thought they would snap. I’m looking for a replacement set that will correct this problem. Ideas ?
