JKbrick
Getting ready to run some waterlines next week
[emoji631] USA [emoji631]
What’s the white used for?
Some people around here use all white but it’s how I differentiate well water or unsoftened/not treated water. It’s easier to keep track of the colors for me
Pulled a little Dana axel today. I actually can’t wait to open this one up! View attachment 354816View attachment 354817View attachment 354818View attachment 354819View attachment 354820
I was curious about that as well, when we had some work done over summer they used all the white/ clear stuff. When the house has all Red/blue, Thought it was a different kind of pipe, is it the same pex then just white?
Those axles are insane, I’ve always wondered what it would be like having those axles and steering components under my Jeep.
What’s wrong with it?
My father-in-law owns a plumbing company and showed me this last year when he helped me reroute some waterlines so I could lower my high top bar wall. Its pretty slick how it works. Sucks you have to buy the expanding tool and it only does that.Probably, regular pex uses fittings that go inside the pipe but the od of the fitting is the id of the pipe then some type of crimp ring is used, but that restricts the flow. On a normal home that’s not a big deal. The pipe in my picture is cold expansion pex, which the id of the fitting is the same id as the pipe, uses a pex “crimp” ring, and is not flow restrictive. You put the ring on, expand the pipe and the ring from the inside, put the fitting in it then it shrinks back around the fitting.
I’ve had that same thought!! Silly low gearing.
It blew a break seal. So it filled the differential with hydraulic fluid. The break system is inside the axel.
Cool view.View attachment 354821
Great views of Nashville at the new Amazon headquarters.
I'm getting ready to re-plumb my house with pex. Trying to learn about it. Seems pretty simple, but noticed there are copper clamp rings, stainless, crimp rings, and stainless clamp sleeves. What do you prefer, other than the expandable type?Did he show you how the pipe fixes itself if you kink it? It is a bummer about the tools, my 12v only do up to 1”, and we can do up to 1 1/2” with the 18v, luckily our local supply house has the tool for 2” and lets everyone use it. They make 3” now and I believe 4” even. At least with pro press you can do copper, stainless, and steel with mega press jaws in that tool
I had no idea the breaks were inside, that’s weird. How much of a pain is it to fix that?
My geo-thermal guys, liked the stainless crimp rings and used a one handed ratchet type, crimper. Since they started with that, I figured I would do the same. What say you?
The square housing reminds me of my monster truck days back in the 80s
That's probably why the HVAC guys were using stainless. Also, it seems like they could get up between floor joists easy with their one handed ratchet style crimper. I'll probably just go ahead and buy one. Or maybe use some Menards rebate coupons to get one.I carry the stainless in my truck only because 1 tool crimps all sizes so for a homeowner doing your own house you’d only need to purchase 1 crimper. But the ss rings cost more too. All my trucks have multiple crimpers and carry copper crimp rings. I can send you my crimper to use if you don’t want to buy one.
Thanks for the generous offer to loan. This will probably be a little at a time, project.
