Mike Pierson
On both front and back, the longer end is inboard.question for the coil over pros, which way does the larger side of the spacer face, inward or out
What Mike said, the long side of the spacer goes toward the frame.question for the coil over pros, which way does the larger side of the spacer face, inward or out
good to know!I admit I was dumb enough to follow the aux battery delete trend on YouTube. But after reading Eddie's post about the aux battery protecting the computer, I quickly plugged everything back together.
What I learn when you unplug the aux battery, there are no warning lights because it disables them. Right after I put my aux battery back, I got a fuel cap warning and slow emissions leak check engine light. I've been driving almost 300 miles with the fuel cap off without any warning lights. I don't think it's coincidence.
Awesome choices! Those will look great against the blue. Glad that little man got the rings torqued to spec too!!!Found a set of KMC Tanks for a decent price and got them mounted for the wife’s rig. Her tires also need to be replaced so went in on a set of Trail Grappler’s in a 38.
Thanks Eddy for providing a good how to video on deadlocks.
And of course when little man came home, he wanted to help. But he also took away my TV privileges lol. View attachment 434592
Yea he enjoyed putting everything together (mostly hitting the tire with a dead blow hammer).Awesome choices! Those will look great against the blue. Glad that little man got the rings torqued to spec too!!!
LOL - awesomeFound a set of KMC Tanks for a decent price and got them mounted for the wife’s rig. Her tires also need to be replaced so went in on a set of Trail Grappler’s in a 38.
I've been trying to find a wheel shop that would machine the ATX for that new look but painting is a good idea. what type paint did you use?I too have started a beadlock mounting project. Or rather, a new tire mounting project and since my ATX Chamber pros have really taken a beating, I’ve decided to clean them up and give them a fresh coat of paint.
Oh and new shoes of course.
Yeah I’ve had that issue with other wheels too. When I bought these way back in 2017 they were a blemish sale as they didn’t have any clear coat. I got soooo tired of trying to keep them clean I bead blasted them and then rattle canned them.I've been trying to find a wheel shop that would machine the ATX for that new look but painting is a good idea. what type paint did you use?
last time I tried to paint aluminum it peeled off
I use this same paint on all by touch up applications.Yeah I’ve had that issue with other wheels too. When I bought these way back in 2017 they were a blemish sale as they didn’t have any clear coat. I got soooo tired of trying to keep them clean I bead blasted them and then rattle canned them.
I used the VHT Roll bar and chassis paint in satin black.
Lasted for about 4 years and now that I’m doing tires again, decided to freshen them up. Three coats and then one coat of clear over that.
Good stuff. It matches EVO stuff perfectly.I use this same paint on all by touch up applications.
It matches great with powder coating.
