This all sounds great. But what effects are there on things like the ABS, traction control , hill descent, and any other braking guided by the Jeep computer?Gladiator rotors are larger in diameter and have more swept area than the JK rotors
So the proportion/rate of the control will still be ok even though hydraulics such as the master cylinder need to be upgraded for the larger volume?The computer gets its info from the tone rings and the gizmotoid in the center console and controls the brakes accordingly. The computer tells each brake how much to brake according to the feed back the tone rings and gizmotoid gives it.
Before and after the Earth orbits around the sun a few hours or what? Where did the Jeep go?!?Buttoned up, on all 4 tires, and ready to roll.
Found some things I missed, so went over everything again this morning with the torque wrench.
Before
After
In the fricken shade since it's heading to 95 degrees and the humidity is around 90%.Before and after the Earth orbits around the sun a few hours or what? Where did the Jeep go?!?
Lol, looks like a good height. Tires next?In the fricken shade since it's heading to 95 degrees and the humidity is around 90%.
Yup. Still surprised that the 35's don't look as bad as I thought they would. But 37's are next on the menu.Lol, looks like a good height. Tires next?
After is much darker! More stealthy!Buttoned up, on all 4 tires, and ready to roll.
Before
After
Welcome to the heat dome beyond thunderdome.In the fricken shade since it's heading to 95 degrees and the humidity is around 90%.
Awesome! Hope the balljoint rebuild went smooth.Thanks to @Disciple Off Road.
Synergy TREs and Dynatrac Rebuild Kit.
Replaced fuel injectors and camshaft position sensor seals, and wheel hubs as well…
View attachment 408741View attachment 408742
Put some exhaust wrap around my coolant lines. Air box and wires on the valve cover have been jamming into them a little since stuffing the PSC reservoir in there.
Good call on the Synergy stuff!Thanks to @Disciple Off Road.
usually around 100k when you do the plugs and coils; get it all done while it's apartGood call on the Synergy stuff!
How many miles before replacing the injectors and those seals? Trying to get an idea of what to watch out for on my 3.6 ahead of time - I’m at 77k now.
