JamesWyatt
Good to hear. Seems pretty solid to me. I just ordered the cigarette lighter USB port thing so I can get the faster charging.I've had my Bulletpoint mount for a while now, still happy with it![]()
Pics or it didn’t happen.No, no pictures, you all know what it looks like anyway. When I'm done I'll post up before and after for the comparison.
Going to look good! Looking forward to seeing it all togetherBuild day is next weekend, but got a bunch of goodies in this week! Big thanks to @Disciple Off Road for getting it all together for me.
It is amazing how Disciple Off Road is able to get all this top quality stuff delivered on tme. Better performance than the big online outfits!Going to look good! Looking forward to seeing it all together![]()
It has a lot to do with building direct relationships with the companies we work with and their ability to ship out products quickly for usIt is amazing how Disciple Off Road is able to get all this top quality stuff delivered on tme. Better performance than the big online outfits!
Okay "Kid", here you go. Still moving slow, removed calipers and hung them up, drilled the holes for the rear bump stops and installed. Drilled the holes for the track bar relocation bracket and installed.Pics or it didn’t happen.
Why does the brake rotor have surface rust in just one spot?Replacing ball joints. Had a set of ball joints for the right side. Need to order ball joints for the left
That's not rust. It's light reflecting off the cushion I was using for a kneeling pad. The disc looks rough because I used a sanding pad to break the glaze on the rotor. It was running too hot while the ESC was trying to compensate for the bad ball joints. Later, when the budget allows, I'll replace the disc & calipers with upgrades.Why does the brake rotor have surface rust in just one spot?
Never fails!Washed and waxed both Jeeps this weekend… then it rainedView attachment 408404View attachment 408403
Every damn timeWashed and waxed both Jeeps this weekend… then it rainedView attachment 408404View attachment 408403
These fit on a JK?Ordered JL Rubicon front brake calipers, rotors and pads. Might as well upgrade the brakes while doing the ball joints.
YesThese fit on a JK?
