GraniteCrystal
What is a suckdown winch?
It allows you to pull the front end down so on steep climbs help keep the front end down and wont let the suspension unload.
or a suck down wench
Question, why add a suck down winch instead or routing or winch cable instead (more weight savings)?
As far as fuel cells I have run the stock lines and extended. Are you sunking it on the bed or running above the tub? Mine was above the tub, behind teh rear seat,. Couple issues were the space killed and once ina while a bit of fuel smell. You can also route your lines nicely so in case of a roll you will not have gas dripping inside the cab (no good).
Check online for FATS (fuel air trap system). There is a great write up from Billavista on how to properly set up a fuel cel and FATS system here:
http://billavista.com/tech/Articles/Fuel_Cell/index.html
On mine, I run somewhat similar to this:
Gui
Gotcha. Thanks.
RD@ROK very clean setup and love how you used th skid over the evap, cool idea! Any ay to move that outta there (i.e. next to the tank of by the rear cubby hole?
For the suck down winch what I have done on my previous Jeeps and buggies was to have an access area behind the mounting plate so the line could be moved and run from there (disconnect hook and re-route when needed), or used a loop under the frame and loop welded to the center of axle for suckdown. Crappy pic below, and I was not using (and should have ) used the suck down on this climb. On the center by the Ram I had a hoop and re-routed the winch cable from the back as needed:
But I agree, having it ready to go whenever you need it is a huge plus!
Looking good!!!! Did you shut off your hot water heater before spraying? Looking at your masking job, I'm gonna guess you've done a lot of painting before. [emoji6]
Looking at these pictures, your Jeep would look badass all black as well [emoji108]
Black & red is a good combo...looking sweet!
