TORQUE SPECS : JL WRANGLER Reference Guide
Status
Not open for further replies.
REAR SUSPENSION
DescriptionN·mFt. Lbs.In. Lbs.Comments
Lower control arm front bolts100 + 50°74 + 50°-
Lower control arm rear nut100 + 50°74 + 50°-
Shock absorber upper bolt11081-
Shock absorber lower nut10074-
Stabilizer bar bolts6346-
Stabilier bar link upper nut9066-
Stabilizer bar link lower nut8059-
Track bar nut (frame end)100 + 30°74 + 30°-
Track bar bolt (axle end)100 + 60°74 + 60°-
Upper control arm front bolt100 + 80°74 + 80°-
Upper control arm rear nut100 + 65 °74 + 65°-
RESTRAINTS
B-Pillar impact sensor nut9-80
Clockspring mounting screw6-53
Driver airbag to steering wheel bolts9-80
Front turning loop height adjuster mounting bolts4533-
Front impact sensor nut118-
Front seat belt buckle bolt4030-
Front retractor pretentioner bolt4533-
Front retractor pretentioner bracket to B-Pillar bolts2619-
Front retractor to B-Pillar bolt4533-
Front seat belt turning loop mounting nut3929-
Occupant restraint controller mounting nut118-
Passenger airbag mounting bolts1813-
Seat airbag mounting nut107-
Rear center retractor to seat frame bolt7052-
Rear center retractor to floor bolt7052-
Rear retractor to C-Pillar bolt3224-
Rear retractor belt to floor nut4835-
Rear seat belt buckle to floor bolt7052-
Rear seat belt buckle to seat frame nut4030-
Rear turning loop to sport bar3224-
STEERING COLUMN
Steering wheel nut5037-
Steering column nuts2720-
Intermediate shaft coupler pinch bolts5440-Do NOT reuse
these fasteners.
If removed, a
NEW fastener
MUST be installed
and tightened to
specifications.
STEERING GEAR
Adjuster screw lock nut4533-
Power steering gear bolts13399-
Power steering gear pitman shaft nut250184-
Power steering gear pressure line2821-
Power steering gear return line2821-
STEERING LINKAGE
Drag link inner nut (at pitman arm)10577-
Drag link outer nut (at steering knuckle)6447-
Drag link adjuster clamp4634-
Tie rod end nut (at steering knuckles)6447-
Tie rod end adjuster clamp4634-
Steering damper bolt (at axle)8059-
Steering damper nut (at tie rod)8059-
Steering damper bracket nut7555-
STEERING PUMP
Power steering pump bracket to frame2821-
Power steering pump to bracket8671
Pressure line to pump2015-
Power steering hose routing bracket bolt6553
Power steering fluid reservoir bolt6553
TRANSFER CASE - FULL TIME (Selec Track)
Poppet plug2015-
Drain/fill plug2821-
Case half bolts2619-
Output flange nut225166-
Transfer case to transmission bolts6044-
Shift motor (actuator) bolts129-
Range position switch2720-
Extension housing bolts2619-
Range lever bolt3022-
TRANSFER CASE - PART TIME
Poppet plug2015-
TIRES & WHEELS
Spare tire carrier lug nut8059-
Tire pressure sensor nut1.4-12
Spare tire carrier bolt17.513-
Lug Nut/Bolt Torque**Lug Nut/Bolt SizeLug Nut/Bolt Socket Size
130 Ft-Lbs (176 N·m)M14 x 1.522mm
TRANSMISSION - AUTOMATIC
Engine to bell-housing bolt6044-
Extension housing to transmission bolt2720-
Manual park release lever shaft nut10-89
Manual park release cable to transmission2015-
Manual park release grommet to bracket9-79
Manual park release lever to transmission shaft2015-
Manual park release shield to transmission1712-
Output shaft flange nut6044-
Output speed sensor bolt8-71
Park pawl lock rod guide plate bolt10-89
Park pawl shaft plug3526-
Shifter assembly bolts9-79
Transmission oil pan bolt10-89
Transmission oil pan drain plug9-80
Transmission oil fill plug3526-
Transmission oil pump housing to cover bolt5 + 45°-44 + 45°
Torque converter to flex plate bolt5541-Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specifications.
NOTE: If old fastener must be reused, Loc-Tite® must be applied to the threads.
Transmission mount to adapater3022-
Shift lever assembly to floor pan bolts8-70
Transmission shift knob2-17
Transfer case shift knob2-17
Manual park release to shift lever assembly8-70
TRANSMISSION - MANUAL
Drain plug3022-
Fill plug3022-
Shifter base to floor assembly bolts8-70
Control shaft cover assembly bolts2518-
Shift lever bolt8-70
Output speed sensor bolt8-70
Transmission stroke sensor bolts2518-
Input shaft retainer bolts9-80
Clutch release bearing retainer bolts10-88
Output shaft lock nut
Shift fork detent bolts2518-
Shift fork support bolts8-71
Reverse idler gear shaft bolts2015-
Countershaft bolt10074-
Transmission case bolts4030-
Transmission oil separator bolts---
Transmission shift guide plate bolts---
Transmission mount bolts4735-
Shift cable retaining bracket2216-
Fuse Box Quick Reference Chart
NOTE: The following information was setup using tables and you will NEED to use a computer or view it from the full site to see it formatted correctly.
LocationDescriptionSizeType
F01Spare
F02Starter40 Amp GreenCartridge
F03IBS5 Amp TanMicro
F04Fuel Pump MTR/FPCM20 Amp YellowMicro
F05Security Gateway5 Amp TanMicro
F06Spare
F07LTR Cool Pump — If Equipped15 Amp BlueMicro
F08TCM-8HP CYGNUS15 Amp BlueMicro
F09Spare
F10KIN/RF HUB/ESCL15 Amp BlueMicro
F11UCI Port (USB & AUX)10 Amp RedMicro
F12HIFI Ampliftier25 Amp ClearMicro
F13Spare
F14Spare
F15IPC/SWITCH BANK-HD ELEC15 Amp BlueMicro
F16Spare
F17Spare
F18AC CLUTCH10 Amp RedMicro
F19Spare
F20CBC 1-INTERIOR LIGHTS30 Amp PinkCartridge
F21REAR WIPER20 Amp YellowMicro
F22ECM/PCM/MGU WAKE UP/PPU WAKE UP10 Amp RedMicro
F23PCM/ECM10 Amp RedMicro
F24Spare
F25MOD_SBW10 Amp RedMicro
F26CBC 2-EXTERIOR LIGHTS #140 Amp GreenCartridge
F27Front Wipers30 Amp PinkCartridge
F28CBC 3-POWER LOCKS40 Amp GreenCartridge
F29CBC 4-EXTERIOR LIGHTS #240 Amp GreenCartridge
F30Spare
F31DIAGNOSTIC PORT10 Amp RedMicro
F32HVAC CTRL MOD/SCL/OCM/DPDM10 Amp RedMicro
F33PTS/IRCM/AIRBAG DISABLE LMPS10 Amp RedMicro
F34ESC/EHPS/SBCM WAKE UP10 Amp RedMicro
F35BRAKE VAC PMP — If Equipped30 Amp PinkCartridge
F36TRLR TOW MOD — If Equipped30 Amp PinkCartridge
F37TRLR TOW CONN 7W — If Equipped30 Amp PinkCartridge
F38ECM20 Amp BlueCartridge
F39Spare
F40DTCM/AXLE LOCK FT_RR15 Amp BlueMicro
F41IC/SGW WAKE UP15 Amp BlueMicro
F42PCR CTRL FEED (ESS)/SPARE (BSG) — If Equipped10 Amp RedMicro
F43PWR OUTLET (CARGO) BATT20 Amp YellowMicro
F44IRCAM HEATERS10 Amp RedMicro
F45PWR OUTLET (CARGO) IGN*20 Amp YellowMicro
F46AUTO HDLP LVL MOD/LVL MTR/HDLP SW10 Amp RedMicro
F47Spare
F48Spare
F49ORC10 Amp RedMicro
F50HD ACC — If Equipped10 Amp RedMicro
F51DSRC/USB/ISRVM/CSGM10 Amp RedMicro
F52CIGAR LTR20 Amp YellowMicro
F53Spare
F54Spare
F55Spare
F56IN-CAR TEMP SENSOR10 Amp RedMicro
F57Frt Drvr Htd Seat20 Amp YellowMicro
F58Frt Pass Htd Seat20 Amp YellowMicro
F59Spare
F60CSWM (HTD STR WHEEL)15 Amp BlueMicro
F61LBSS/RBSS10 Amp RedMicro
F62Spare
F63ORC10 Amp RedMicro
F64Spare
F65Spare
F66HVAC BLOWER MTR FRT40 Amp GreenCartridge
F67Spare
F68Spare
F69MGU (BSG) — If Equipped5 Amp TanMicro
F70INJ/IGN COIL (GAS)/GLO PLUG MOD (DSL)25 Amp ClearMicro
F71Spare
F72HD ELEC ACC PKG — If Equipped10 Amp RedMicro
F73PWR TOP LT20 Amp BlueCartridge
F74PWR TOP RT20 Amp BlueCartridge
F75PPU-BPCM & APM (BSG) — If Equipped10 Amp RedMicro
F76ECM (GAS)/PCM (DSL)20 Amp YellowMicro
F77HTD MIRRORS10 Amp RedMicro
F78COMP/INTRUSION/SIREN/INTRUSION SNSRS10 Amp RedMicro
F79SMART BAR CTRL MOD20 Amp YellowMicro
F80PCM15 Amp BlueMicro
F81REAR DEFROSTER (EBL)30 Amp PinkCartridge
F82FUEL HTR — If Equipped30 Amp PinkCartridge
F83GLOW PLUG — If Equipped60 Amp YellowCartridge
F84UREA HTR CTRL UNIT — If Equipped30 Amp PinkCartridge
F85PM SENSOR — If Equipped10 Amp RedMicro
F86BRAKE VAC PMP 2 — If Equipped30 Amp PinkCartridge
F87SUPPLY/PURGING PMP — If Equipped10 Amp RedMicro
F88NOx SENSOR #1/ #2 — IF Equipped20 Amp BlueCartridge
F89SCCM/CRUISE CTL/DTV10 Amp RedMicro
F90TRLR TOW PARK LMP — If Equipped20 Amp BlueCartridge
F91HORN20 Amp YellowMicro
F92HD ACCY #2 — If Equipped40 Amp GreenCartridge
F93HD ACCY #1 — If Equipped40 Amp GreenCartridge
F94TPM/CORAX10 Amp RedMicro
F95Spare
F96PWR MIRROR SW10 Amp RedMicro
F97RADIO/TBM20 Amp YellowMicro
F98SW BANK-HD ELEC/OFF ROAD10 Amp RedMicro
F99Spare
F100ESC-ECU & VALVES30 Amp PinkCartridge
F101DTCM30 Amp PinkCartridge
F102DUAL USB PORT15 Amp BlueMicro
F103HD ACCY #3 — If Equipped15 Amp BlueMicro
F104PPU COOL PUMP — If Equipped15 Amp BlueMicro
F105ICS/HVAC10 Amp RedMicro
F106ESC-PUMP MTR40 Amp GreenCartridge
F107TRLR TOW STOP/TURN LT — If Equipped20 Amp YellowMicro
F108HD ACCY #4 — If Equipped15 Amp BlueMicro
F109TRLR TOW STOP/TURN RT — If Equipped20 Amp YellowMicro
F110POWER INVERTER30 Amp PinkCartridge
F110TRLR TOW BACKUP — If Equipped20 Amp BlueCartridge
POWER DISTRIBUTION CENTER
The fuses on a Jeep JL Wrangler are located under the hood and in a black box next to the battery. This box is known as the Power Distribution Center and the top cover has a diagram of all the cartridge fuses, mini fuses and relays contained within it.
Because it can some times be hard to read, the following is a complete list of them according to what bank they're in, what they're used for and what type, size and color fuse is needed to replace them.
LOCATION / DESCRIPTION / SIZE & TYPE
F01 - Spare
F02 - Starter
40 Amp Green - Cartridge
F03 - IBS
5 Amp Tan - Micro
F04 - Fuel Pump MTR/FPCM
20 Amp Yellow - Micro
F05 - Security Gateway
5 Amp Tan - Micro
F06 - Spare
F07 - LTR Cool Pump — If Equipped
15 Amp Blue - Micro
F08 - TCM-8HP CYGNUS
15 Amp Blue - Micro
F09 - Spare
F10 - KIN/RF HUB/ESCL
15 Amp Blue - Micro
F11 - UCI Port (USB & AUX)
10 Amp Red - Micro
F12 - HIFI Amplifier
25 Amp Clear - Micro
F13 - Spare
F14 - Spare
F15 - IPC/SWITCH BANK-HD ELEC
15 Amp Blue - Micro
F16 - Spare
F17 - Spare
F18 - AC CLUTCH
10 Amp Red - Micro
F19 - Spare
F20 - CBC 1-INTERIOR LIGHTS
30 Amp Pink - Cartridge
F21 - REAR WIPER
F22 - ECM/PCM/MGU WAKE UP/ PPU WAKE UP
10 Amp Red - Micro
F23 - PCM/ECM
10 Amp Red - Micro
F24 - Spare
F25 - MOD_SBW
10 Amp Red - Micro
F26 - CBC 2-EXTERIOR LIGHTS #1
F27 - Front Wipers
F28 - CBC 3-POWER LOCKS
F29 - CBC 4-EXTERIOR LIGHTS #2
F30 - Spare
F31 - DIAGNOSTIC PORT
10 Amp Red - Micro
F32 - HVAC CTRL MOD/SCL/OCM/DPDM
10 Amp Red - Micro
F33 - PTS/IRCM/AIRBAG DISABLE LMPS
10 Amp Red 0 Micro
F34 - ESC/EHPS/SBCM WAKE UP
10 Amp Red - Micro
F35 - BRAKE VAC PMP — If Equipped
F36 - TRLR TOW MOD — If Equipped
F37 - TRLR TOW CONN 7W — If Equipped
F38 - ECM
20 Amp Blue - Cartridge
F39 - Spare
F40 - DTCM/AXLE LOCK FT_RR
15 Amp Blue - Micro
F41 - IC/SGW WAKE UP
15 Amp Blue - Micro
F42 - PCR CTRL FEED (ESS)/SPARE (BSG) — If Equipped
10 Amp Red - Micro
F43 - PWR OUTLET (CARGO) BATT
F44 - IRCAM HEATERS
10 Amp Red - Micro
F45 - PWR OUTLET (CARGO) IGN*
F46 - AUTO HDLP LVL MOD/LVL MTR/HDLP SW
10 Amp Red - Micro
F47 - Spare
F48 - Spare
F49 - ORC
10 Amp Red - Micro
F50 - HD ACC — If Equipped
10 Amp Red - Micro
F51 - DSRC/USB/ISRVM/CSGM
10 Amp Red - Micro
F52 - CIGAR LTR
F53 - Spare
F54 - Spare
F55 - Spare
F56 - IN-CAR TEMP SENSOR
10 Amp Red - Micro
F57 - Frt Drvr Htd Seat
F58 - Frt Pass Htd Seat
F59 - Spare
F60 - CSWM (HTD STR WHEEL)
15 Amp Blue - Micro
F61 - LBSS/RBSS
10 Amp Red - Micro
F62 - Spare
F63 - ORC
10 Amp Red - Micro
F64 - Spare
F65 - Spare
F66 - HVAC BLOWER MTR FRT
F67 - Spare
F68 - Spare
F69 - MGU (BSG) — If Equipped
5 Amp Tan - Micro
F70 - INJ/IGN COIL (GAS)/GLO PLUG MOD (DSL)
F71 - Spare
F72 - HD ELEC ACC PKG — If Equipped
10 Amp Red - Micro
F73 - PWR TOP LT
F74 - PWR TOP RT
F75 - PPU-BPCM & APM (BSG) — If Equipped
10 Amp Red - Micro
F76 - ECM (GAS)/PCM (DSL)
F77 - HTD MIRRORS
10 Amp Red - Micro
F78 - COMP/INTRUSION/SIREN/INTRUSION SNSRS
10 Amp Red - Micro
F79 - SMART BAR CTRL MOD
F80 - PCM
15 Amp Blue - Micro
F81 - REAR DEFROSTER (EBL)
F82 - FUEL HTR — If Equipped
F83 - GLOW PLUG — If Equipped
60 Amp Yellow
F84 - UREA HTR CTRL UNIT — If Equipped
30 Amp Pink
F85 - PM SENSOR — If Equipped
10 Amp Red - Micro
F86 - BRAKE VAC PMP 2 — If Equipped
F87 - SUPPLY/PURGING PMP — If Equipped
10 Amp Red
F88 - NOx SENSOR #1/ #2 — IF Equipped
F89 - SCCM/CRUISE CTL/DTV
10 Amp Red - Micro
F90 - TRLR TOW PARK LMP — If Equipped
F91 - HORN
F92 - HD ACCY #2 — If Equipped
F93 - HD ACCY #1 — If Equipped
F94 - TPM/CORAX
10 Amp Red - Micro
F95 - Spare
F96 - PWR MIRROR SW
10 Amp Red - Micro
F97 - RADIO/TBM
F98 - SW BANK-HD ELEC/OFF ROAD
10 Amp Red - Micro
F99 - Spare
F100 - ESC-ECU & VALVES
F101 - DTCM
F102 - DUAL USB PORT
15 Amp Blue - Micro
F103 - HD ACCY #3 — If Equipped
15 Amp Blue - Micro
F104 - PPU COOL PUMP — If Equipped
15 Amp Blue - Micro
F105 - ICS/HVAC
10 Amp Red - Micro
F106 - ESC-PUMP MTR
F107 - TRLR TOW STOP/TURN LT — If Equipped
F108 - HD ACCY #4 — If Equipped
15 Amp Blue - Micro
F109 - TRLR TOW STOP/TURN RT — If Equipped
F110 - POWER INVERTER
F111 - TRLR TOW BACKUP — If Equipped
20 Amp Blue Cartridge
* Customer can select to switch the Cargo Power Outlet from F43 battery fed power to this position F45 which is fed when the ignition in ON.
Status
