Whether you're doing routine maintenance or installing a new component on your Jeep JL Wrangler, it's important to tighten any bolt or nut you work on, back to its appropriate torque settings. The quick links you see below have been arranged alphabetically and by category and they will take you to reference charts that'll help you to find the torque setting you need.
QUICK LINK DIRECTORY
ABS
Body
Brakes
Clutch
Cooling
EGR
Engine
EVAP
Exhaust
Frame & Bumpers
Front Suspension
Fuel Delivery
HVAC
M186 Front Axle
M200 Rear Axle
M210 Front Axle
M220 Rear Axle
Propeller Shafts
Rear Suspension
Restraints
Steering Column
Steering Gear
Steering Linkage
Steering Pump
Transfer Case - Full Time Select Trac
Transfer Case - Part Time
Tires & Wheels
Transmission - Automatic
Transmission - Manual
NOTE: The following information was setup using tables and you will NEED to use a computer or view it from the full site to see it formatted correctly.
ABS
Body
Brakes
Clutch
Cooling
EGR
Engine
EVAP
Exhaust
Frame & Bumpers
Front Suspension
Fuel Delivery
HVAC
M186 Front Axle
M200 Rear Axle
M210 Front Axle
M220 Rear Axle
Propeller Shafts
Rear Suspension
Restraints
Steering Column
Steering Gear
Steering Linkage
Steering Pump
Tires & Wheels
