TonyViv
So, if you look back I have threads over the last year or so dealing with death wobble. You can look back and read the history. I searched and searched, fixed everything that needed to be fixed, all was good for a while and it started back up again.
Long story short, I went back to the shop that fixed it and they said the front end was solid must be a tire problem. Ok Went to another shop.. same thing. These were both long time "chain" type off road shops but I had confidence in the original guy that fixed me up. They had every incentive to sell me more parts as warranties were out and didn't.
Finally had enough and went to a well renowned off road shop here in Phx ( not sure if I can mention names) to check things out. They took their time checked everything, made a few minor tweaks to my caster and toe and came to the conclusion that my front end was solid and my tires were the problem. I had some "wavy" kinda wear to my tires and they feel confident that is the problem. Again they have every opportunity to sell me something but did not and sent me on my way with no charge and asked I just let them know if what they did helped. Other than when it wobbles it has better road manners than it ever has..
The tires are Yokohama geolander AT/S 315/70/17.... Yes they are 5 1/4 years old with 40k on them but they all measure 9-10 32nds(over half tread left) and all have even wear and are wearing the same with constant rotations and balances every 3k miles. what tires go bad with that much tread left... Although in retrospect, I almost feel like the wobbles get better/ worse with rotations... so maybe..
Again from everything I have read, tires cant cause DW, but can instigate it..... but if I have 3 shops plus the countless hours I have laying under with my daughter turning the wheel back and forth... I don't know where else to look
Some days I have no problems/ today it was bad. Sometimes I can hit a big ass bump and nothing, sometimes I can roll over an ant and stuff goes ballistic, no rhyme or reason..
I am going to discount tomorrow to see if there is anything they will/can do. Maybe a road force balance will help, Ill ask
In the long run, I don't think Discount will do much for me. I have a hard time spending 1500 on a new set of real 35s without feeling really confident it will fix my problem.
So does anyone have any thoughts or ideas? Im at the point where I cant let my wife drive my jeep for her safety.
Here is the real crazy part...... Is there another jeeper in the phoenix area on good 35s that might be willing to swap wheels/tires with me for an hour or 2 / day to see if the problem moves with my tires. Ill do all the work..... 1500+ Is a lot of cash and I need to be sure. I especially trust the last shop but I really need to be sure.
Thanks everyone for your help and reading my rant
Tony
On the plus side, I put in a new thermostat. That fixed my slow heat and p0128 code..... but why did DC incorporate a 2 dollar thermostat into a 20+$ housing? HMM
I guess that's for another thread........ ~
Tony
