Rubiwho
Out of curiosity how long did it take you to install the AEV lift? Did you do it yourself and any trouble/tips you have? Lift is in the mail.
Sent from my DROID RAZR using WAYALIFE mobile app
I've done it twice a myself, both times the 3.5". First time it took about 11 hours, 5 on day 1 and 6 in day 2. It took about 9 the second go around. Very straight forward. The really isn't hard, it's all about the tools. I broke the track bar bolt on the second install... My torque bar wasn't clicking at 125 lbs, so I kept turning (knew something wasn't right)... snap... #%^#. Take 2 days, day 1 do the back and start the front. Day 2 finish the front and do the geo brackets and set pro-cal stuff. If your using Jack Stands and not a hydraulic lift you will be sore in the morning. Make sure you have the drill bits before you start. The bit for the knuckle was hard to find. Found it at Granger. When you do the brake lines you may think your missing something because the brakes line brackets don't remount, just zip tie them up. The second time I bought new extended brake lines and didn't use the drop down brackets.
Good Luck
