Rock lights
Krieger
I was just taking a closer look at your pics and was wondering what you used as adhesive for the brackets? Didn't see any screw holes. Did you burn those on? Hot glue gun or silicone? Thanks for you help!
I used 3M outdoor two sided foam tape, just clean the surface real good and apply. Other than that I used little dabs of hot glue, it holds good and isn't permanent. I hope this helps and
Post up some photos when you get it done. Cheers!!
Trail JK
Yep will do! Thanks!
