Rear Wheel Bearing noise?
Brute
Sometimes if the backing plate is really close it will rub the rotor when things warm up. Noise wise it sounds much like a bent flange as mentioned but where you just had rotors replaced it could be a small casting difference scraping the rotor when it heats up.
This actually sounds most likely...it gets more pronounced the longer I drive...
