Rear drive line removal problems
mauijim
So I have a 2012 JK sport that I'm swapping axles out with front and rear Dana 44's from a Rubicon. The front was a breeze and the rear was until the driveline won't come apart. I have removed the 8 bolts but it just doesn't want to separate. I'm new at this and I need some help. Any suggestions on what to do or what I haven't done? Please help.
They are usually just a little stuck on there. I had to tap mine a few times with a soft mallet just to free it up a little. It should come off after a few light hits.
Best I remember, there's a few small holes thru the back side of the yoke, you can tap the joints out of the yoke hopefully pretty easily that way. I'll see if I can find one of my old ones and get a pic. I discovered these the hard way... AFTER spending WAY to much time tapping all around with a rubber mallet. A few taps on either side with a flat punch and it was out.
Something like that, use the larger non threaded holes.
This is the key. Once you get it started with a punch/screwdriver/etc. it should wiggle free pretty easily.
Just use the short end of the allen wrench you use to remove the bolts. Light taps around in a circle gets it done
Hey thanks everyone...I got it apart and was very easy actually....used the center punch with a 2 lbs hammer and hit the side slightly and bam !!! It popped right out!!!! Thanks again everyone!!!![emoji41][emoji1303]
