tylerbrinks
I reinstalled the drive shaft in between trips and only had time to drive around the block, so we'll have see how things shape up once I have a chance to give it a proper test run. The drive shaft was in great shape after it's checkup with the fabricator ("was" being the key word). He added just a bit of weight to the slip side. Hopefully I'll be able to continue to narrow down the noise source next week.
I made the bonehead mistake of trying to reinstall the shaft without lifting the rear end or connecting both ends of the shaft. I put the Jeep in neutral having only 2 of the 4 t-case yoke bolts secured to rotate the DS. There was enough fluid movement in the transmission that it spun the drive line with the shaft at full droop (CV side by the t-case) and thrashed the slip end on my garage floor. Despite my lapse in attention, the drive shaft reinstalled okay, and the joints still seemed okay. But now from time to time there's an audible "clunk" when starting from a dead stop (or accelerating?). So it ought to be fun to troubleshoot multiple issues at once. I may just swap out all the u-joints as a precaution and inspect the H-yoke and centering yoke/pin to make sure I didn't damage anything in the process. Like I said, the shaft was in good shape. It's pretty stout, so it's probably fine, but I certainly didn't help my process of making things better.
As a side note, if anyone knows the right thread size for double cardan yoke bolts, I probably need to pick up 4 new bolts. I've taken the DS off and on so many times the edges are starting to round out. That'd be a bad day when I couldn't remove the bolts... Seems like I recall 5/16 x 24 is correct. I really just need to take one to the hardware store, but maybe y'all can save me the pain of removing it yet again.
