Ddays
Nothing is worse then your tranny leaking all over after coming face to face with a blower
Well, you could blow out your rear end and that's never pretty either :icon_crazy:
May want check your calibration. Mine didn’t turn that many rpms with 35s. It should turn less than 2500 at 70
Don’t sweat it too much. Budgets dictate the direction of everyone’s build and if a supercharger is what fit yours, then I hope it works out for you. Now that you have it though you really should spend just a little more and have it dyno tuned so you know exactly what you have. Your installer should have done that anyways to ensure it’s dialed in precisely to your setup.
Also, torque is what you’re after. Forget horsepower numbers since they really don’t do anything for a Jeep.
Also after some coments here I’m not sure if the 5.13s match up with my 33s? It’s running 2400 rpms at 70 mph.
That is surprising but again, I’m not sure what has been done to your Level 10 transmission. That doesn’t sound bad, actually. Maybe you are good with that gearing. Any plans to go with larger tires?
So RIPP uses intune Diablo RM 3000
It seems to me to be running well but I’m use to driving my Audi A8 so this is a completely different beast! Also after some coments here I’m not sure if the 5.13s match up with my 33s? It’s running 2400 rpms at 70 mph.
FWIW, I’m running 37s and 5.13s. At 70mph I’m at 2350rpm.
I'm having a hard time believing you're at 2400 rpm at 70 mph with 33's...my JK6 has 4.88...with 39's, I'm at 2600 at 70...Brute, with 5.38 & 40's, I'm turning 2850 rpm
The transmission is going to play a role too. We all have different transmissions, so it’s apples to oranges.
That's true...my 5th gear is .83
Mine is .69. All else being equal, I guess that means relatively lower engine RPM?
